ALTA  alpha
Public Member Functions | Static Public Member Functions | Friends | List of all members
alta::arguments Class Reference
#include <args.h>
 arguments (int argc, char **const argv)
bool is_defined (const std::string &key) const
 is the elements in the command line ?
bool is_vec (const std::string &key) const
 is the data at the given key in a vector format? No matter the type of the data, this function will test is the mapped string is of type "[ .... ]". It returns false if there is no associated entry.
std::string operator[] (const std::string &key) const
 access the element stored value
void update (const std::string &key, const std::string &val)
 update the value val stored under key key
std::string get_string (const std::string &key, std::string default_value="") const
 acces to the string value associated with the parameter More...
float get_float (const std::string &key, float default_value=0.0f) const
 acces to the float value associated with the parameter key. More...
double get_double (const std::string &key, double default_value=0.0) const
 access to the double value associated with the parameter key More...
int get_int (const std::string &key, int default_value=0) const
 acces to the integer value associated with the parameter key. More...
vec get_vec (const std::string &key, int size, float default_value=0.0f) const
 acces to a vector of float of size size associated with More...
template<typename T >
std::vector< T > get_vec (const std::string &key) const
 access a vector of element of type T of variable length. the string associated with the key key should have the form "[a, b, c]" where a, b, c are of type T.
std::vector< std::string > get_vec (const std::string &key) const
std::pair< T, T > get_pair (const std::string &key) const
 access a pair of element of type T. the string associated with the key key should have the form "a b" where a, b are compatible with type T.
std::string get_cmd () const
 get the reconstructed command line arguments (without the executable name
static arguments create_arguments (const std::string &n)
 Create an argument object from a string describing a command line.
static arguments parse_header (std::istream &input)
 Parse a data file header. More...
Friends
std::ostream & operator<< (std::ostream &out, const arguments &args)
 Friend function to display the content of an argument object.
Member Function Documentation
double alta::arguments::get_double ( const std::string &  key,
double  default_value = 0.0
) const
inline
The default_value argument will be returned if the key has no associated value.
float alta::arguments::get_float ( const std::string &  key,
float  default_value = 0.0f
) const
inline
int alta::arguments::get_int ( const std::string &  key,
int  default_value = 0
) const
inline
std::string alta::arguments::get_string ( const std::string &  key,
std::string  default_value = ""
) const
inline
key.
vec alta::arguments::get_vec ( const std::string &  key,
int  size,
) const
inline
the parameter key.
static arguments alta::arguments::parse_header ( std::istream &  input)
inlinestatic
ALTA file header should appear at the beginning of each file. Each line starts with '#' and describe a couple key, value. For example, parametrizations are described as: PARAM_IN NAME
Note: A header should always start and ends by: ALTA HEADER BEGIN ALTA HEADER END
The documentation for this class was generated from the following file:
