ALTA  alpha
Public Member Functions | List of all members
alta::fitter Class Referenceabstract
#include <fitter.h>
virtual bool fit_data (const ptr< data > &d, ptr< function > &f, const arguments &args)=0
 static function to fit a data set d with the underling function class. Return the best fit (along with fitting information ?)
virtual void set_parameters (const arguments &args)=0
 parse the command line arguments to setup some general options before any fit. Those options should be resilient to multiple call to the fit_data procedure
The documentation for this class was generated from the following file:
