ALTA  alpha
Public Types | Static Public Member Functions | List of all members
alta::params Class Reference
Detailed Description
Any function object or data object should have an associated parametrization.
We use the following convention to defined the tangent, normal and bi-normal of the surface:
#include <params.h>
Public Types
enum  input {
  RUSIN_TH_PH_TD_PD, RUSIN_TH_PH_TD, RUSIN_TH_TD_PD, RUSIN_TH_TD,
  RUSIN_VH_VD, RUSIN_VH, COS_TH_TD, COS_TH,
  SCHLICK_TK_PK, SCHLICK_VK, SCHLICK_TL_TK_PROJ_DPHI, COS_TK,
  RETRO_TL_TVL_PROJ_DPHI, STEREOGRAPHIC, SPHERICAL_TL_PL_TV_PV, COS_TLV,
  COS_TLR, ISOTROPIC_TV_TL, ISOTROPIC_TV_TL_DPHI, ISOTROPIC_TV_PROJ_DPHI,
  ISOTROPIC_TL_TV_PROJ_DPHI, ISOTROPIC_TD_PD, STARK_2D, STARK_3D,
  NEUMANN_2D, NEUMANN_3D, CARTESIAN, UNKNOWN_INPUT
 list of all supported parametrization for the input space. An unsupported parametrization will go under the name ! unknown. We use the following notations: More...
enum  output {
  INV_STERADIAN, INV_STERADIAN_COSINE_FACTOR, ENERGY, RGB_COLOR,
  XYZ_COLOR, UNKNOWN_OUTPUT
 list of all supported parametrization for the output space. An unsupported parametrization will go under the name unknown. More...
static params::input parse_input (const std::string &txt)
 parse a string to provide a parametrization type.
static params::output parse_output (const std::string &txt)
static const std::string & get_name (const params::input param)
 look for the string associated with a parametrization type.
static const std::string & get_name (const params::output)
 look for the string associated with a parametrization type. More...
static double * convert (const double *invec, params::input intype, params::input outtype)
 static function for input type convertion. This function allocate the resulting vector.
static void convert (const double *invec, params::output intype, int indim, params::output outtype, int outdim, double *outvec)
 static function for input type convertion. The outvec resulting vector should be allocated with the correct output size. TODO: RP this function is weird the outtype and intype ARE NEVER USED
static void convert (const double *invec, params::input intype, params::input outtype, double *outvec)
static void to_cartesian (const double *invec, params::input intype, double *outvec)
 convert a input vector in a given parametrization to an output vector in a cartesian parametrization, that is two 3d vectors concatenated.
static void from_cartesian (const double *invec, params::input outtype, double *outvec)
 convert a input CARTESIAN vector, that is two 3d vectors concatenated to an output vector in a given parametrization.
static int dimension (params::input t)
 provide a dimension associated with a parametrization
static int dimension (params::output t)
static bool is_cosine_weighted (params::output t)
 Is the value stored weighted by a cosine factor.
template<typename Real >
static void half_to_cartesian (Real theta_h, Real phi_h, Real theta_d, Real phi_d, Real *out)
 from the 4D definition of a half vector parametrization, export the cartesian coordinates.
static void classical_to_cartesian (double theta_l, double phi_l, double theta_v, double phi_v, double *out)
 from the 4D definition of a classical vector parametrization, export the cartesian coordinates.
template<class Vector , typename Real >
static void rotate_normal (Vector &vec, Real theta)
 rotate a cartesian vector with respect to the normal of theta degrees.
static void rotate_binormal (Vector &vec, Real theta)
 rotate a cartesian vector with respect to the bi-normal of theta degrees.
static void rotate (Vector &vec, Real theta, Real phi)
 Rotate VEC by THETA around the normal, and by PHI around the binormal.
static void print_input_params ()
static bool is_above_hemisphere (double *invec, params::input intype)
 Check whether or not a (light,view) configuration is above the hemisphere. More...
static bool is_below_hemisphere (double *invec, params::input intype)
Member Enumeration Documentation
  • The View vector is \(V\)
  • The Light vector is \(L\)
  • The Normal vector is \(N\)
  • The Reflected vector is \(R = 2\mbox{dot}({V}, {N}){N} - {V}\)
  • The Half vector is \(H = \frac{V+L}{||V+L||}\)
  • The Back vector is \(K = \frac{V-L}{||V-L||}\)
  • The elevation angle of vector \(V\) is \(\theta_V\)
  • The azimuth angle of vector \(V\) is \(\phi_V\)
Enumerator
RUSIN_TH_PH_TD_PD
Half-angle parametrization as described by Rusinkiewicz [1998] described in spherical coordinates. Coordinates are: \( \left[ \theta_H, \phi_H, \theta_D, \phi_D \right] \).
RUSIN_TH_TD_PD
Isotropic Half-angle parametrization. This parametrization is defined by the tuple \( \vec{x} = [\theta_H, \theta_D, \phi_D] \)
RUSIN_TH_TD
Half-angle parametrization with no azimutal information
RUSIN_VH_VD
Half-angle parametrization in vector format. Coordinates are: \( [H_x, H_y, H_z, D_x, D_y, D_z] \).
RUSIN_VH
Half-angle parametrization with no difference direction in vector format. Coordinates are: [ \(\vec{h}_x, \vec{h}_y, \vec{h}_z\)].
COS_TH_TD
Cosine of the RUSIN_TH_TD parametrization: Coordinates are in \( [\cos_{\theta_H},\cos_{\theta_D}] \).
SCHLICK_TK_PK
Schlick's back vector parametrization
SCHLICK_VK
3D Parametrization where the phi component is projected and the parametrization is centered around the back direction. \([\theta_L, x, y] = [\theta_L, \theta_K \cos(\phi_K), \theta_K \sin(\phi_K)]\)
COS_TK
Schlick's back vector dot product with the normal
2D Parametrization where the phi component is projected and the parametrization is centered around the retro direction \([x, y] = [\theta_{VL} \cos(\Delta\phi), \theta_{VL} \sin(\Delta\phi)]\).
STEREOGRAPHIC
Stereographic projection of the Light and View vectors
Light and View vectors represented in spherical coordinates
COS_TLV
Dot product between the Light and View vector
COS_TLR
Dot product between the Light and Reflected vector
ISOTROPIC_TV_TL
Light and View vectors represented in spherical coordinates,
Light and View vectors represented in spherical coordinates, with the difference of azimutal coordinates in the last component
2D Parametrization where the phi component is projected. Coordinates are: \(\left[\theta_v \cos(\Delta\phi), \theta_v \sin(\Delta\phi)\right]\).
3D Parametrization where the phi component is projected. Coordinates are: \(\left[\theta_l, \theta_v \cos(\Delta\phi), \theta_v \sin(\Delta\phi)\right]\).
ISOTROPIC_TD_PD
Difference between two directions such as R and H
STARK_2D
Modified Stark et al. [2005] 2D parametrization by Barla et al. [2015]. This parametrization is defined by the couple \( \vec{x} = ||\tilde{H}_p||, ||\tilde{B}|| \), where \( \tilde{H} = \frac{1}{2}(L+V) \) and \( \tilde{B} = \frac{1}{2}(L-V) \). \( \tilde{H}_p \) is the projected coordinates of \( \tilde{H} \) on the tangent plane.
STARK_3D
Modified Stark et al. [2005] 2D parametrization by Barla et al. [2015]. This parametrization is defined by the tuple \( \vec{x} = \left[||\tilde{H}_p||, ||\tilde{B}||, \phi_B-\phi_H \right] \).
NEUMANN_2D
Neumann and Neumann [1996] parametrization. This parametrization is defined by the couple \( \vec{x} = \left[ ||\tilde{H}_p||, ||\tilde{B}_p||\right] \), where \( \tilde{H} = \frac{1}{2}(L+V) \) and \( \tilde{B} = \frac{1}{2}(L-V) \). \( \tilde{H}_p \) is the projected coordinates of \( \tilde{H} \) on the tangent plane.
NEUMANN_3D
Neumann and Neumann [1996] 3D parametrization. This parametrization is defined by the tuple \( \vec{x} = [||\tilde{H}_p||, ||\tilde{B}_p||, \phi_B-\phi_H] \).
CARTESIAN
View and Light vectors represented in cartesian coordinates. We always pack the view vector first: \([V.x, V.y, V.z, L.x, L.y, L.z] \)
UNKNOWN_INPUT
Default behaviour. Only use this is you do not fit BRDF data.
Enumerator
INV_STERADIAN
Output values in inverse steradian (sr-1). This is the standard definition for a BRDF.
Output values in inverse steradian (sr-1) weighted by the cosine factor of the output direction.
Member Function Documentation
const std::string & params::get_name ( const params::output  param)
static
Todo:
Finish this implementation. It requires another static object.
bool params::is_above_hemisphere ( double *  invec,
static
Returns
true if both vectors (light and view) are above and false otherwise
Remarks
the function returns true also for grazing, tangential configuration (i.e., where light dot normal == 0 or view dot normal == 0)
The documentation for this class was generated from the following files:
