ALTA  alpha
data_astm Class Reference
Detailed Description
This plugin enables to load data measurments from Cornell University program of Computer Graphics (see here). The file format currently only handles integrated luminance [300, 700] and R,G,B color space due to ALTA's internal format. The X,Y,Z color space files should not be used with this plugin.
The resulting data object is a vertical_segment and is compatible with all rational fitting plugins. However, the dimension of the input space is usually not tight (i.e. larger than the dimensionality of the data). Thus it is advised to convert those data file before hand.
Author
Laurent Belcour laure.nosp@m.nt.b.nosp@m.elcou.nosp@m.r@um.nosp@m.ontre.nosp@m.al.c.nosp@m.a
The documentation for this class was generated from the following file:
