ALTA  alpha
data_brdf_slice Class Reference
Detailed Description
This BRDF data format implements the 2D representation of a BRDF presented by Brent Burley in BRDF Explorer. It only stores a slice of the BRDF for different 2D parametrizations. This plugin stores the BRDF data into an EXR file.
It is possible to select the parametrization using the –param NAME argument when loading the BRDF. The default parametrization is STARK_2D
Laurent Belcour
The documentation for this class was generated from the following file:
