ALTA  alpha
data_grid Class Reference
Detailed Description
It is possible to select the parametrization using the –param NAME argument when loading the BRDF. The default parametrization is STARK_2D
Author
Laurent Belcour laure.nosp@m.nt.b.nosp@m.elcou.nosp@m.r@um.nosp@m.ontre.nosp@m.al.c.nosp@m.a
The documentation for this class was generated from the following file:
