ALTA  alpha
data_interpolant_rbf Class Reference
Detailed Description
This interpolation plugin smooth sparse data measurments using radial kernels. The interpolation is performed as:
\( \tilde{y}(\mathbf{x}) = {\sum_{\mathbf{x}_i \in \mathcal{B}( \mathbf{x})} k(\mathbf{x} - \mathbf{x}_i) y_i \over \sum_{\mathbf{x}_i \in \mathcal{B}(\mathbf{x})} k(\mathbf{x} - \mathbf{x}_i)}\)
The kernel is set as \( k(\mathbf{d}) = {1 \over \epsilon + ||d||^2} \).
This plugin requires the FLANN library to compile. On linux plateforms it can be obtained by package libflann-dev and on OSX using the port flann.
Laurent Belcour
The documentation for this class was generated from the following file:
