ALTA  alpha
data_utia Class Reference
Detailed Description
This plugin enables to load any of the 150 measured anisotropic materials released by Filip et al. from the Czech Institute of Information Theory and Automation (UTIA). This format is an HDR image based format using OpenEXR or a binary format if not available. The data is stored as an array of azimuth slices for various elevation angles.
This format is not very dense (only 6 elevation angles per view/light direction) but is quite large.
Laurent Belcour
Original code from Jiri Filip
The documentation for this class was generated from the following file:
