ALTA  alpha
Public Member Functions | List of all members
nonlinear_fitter_ipopt Class Reference
Detailed Description
Third party requirements
You will need three external libraries to compile this plugin:
Plugin parameters
#include <fitter.h>
Collaboration diagram for nonlinear_fitter_ipopt:
Collaboration graph
[legend]
virtual bool fit_data (const ptr< data > &d, ptr< function > &fit, const arguments &args)
virtual void set_parameters (const arguments &args)
 parse the command line arguments to setup some general options before any fit. Those options should be resilient to multiple call to the fit_data procedure
- Public Member Functions inherited from alta::fitter
virtual bool fit_data (const ptr< data > &d, ptr< function > &f, const arguments &args)=0
 static function to fit a data set d with the underling function class. Return the best fit (along with fitting information ?)
The documentation for this class was generated from the following files:
