ALTA  alpha
nonlinear_function_abc Class Reference
Detailed Description
The ABC model has three parameters and models the distribution of microfacets by the following function:
\( D(H) = \frac{A}{\left(1 + B \cos(\theta_{H})\right)^C} \)
This model aims to better reproduce the tail of model acquired BRDF models compared to a Beckmann distribution for example.
Laurent Belcour <>
#include <function.h>
The documentation for this class was generated from the following file:
