ALTA  alpha
nonlinear_function_blinn Class Reference
Detailed Description
A Blinn-Phong lobe has two parameters and is defined as:
\(\rho(L, V)k_s |N.H|^a\), where \( H = \frac{L+V}{|| L+V ||}\).
Author
Laurent Belcour <laure.nosp@m.nt.b.nosp@m.elcou.nosp@m.r@um.nosp@m.ontre.nosp@m.al.c.nosp@m.a>
#include <function.h>
The documentation for this class was generated from the following file:
