ALTA  alpha
nonlinear_function_diffuse Class Reference
Detailed Description
This BRDF model has a constant value for any couple of light-view directions. However, it is not directly used during the fitting procedure. The diffuse function's values are set to be the minimum value in the dataset.
Laurent Belcour <>
#include <function.h>
The documentation for this class was generated from the following file:
