ALTA  alpha
nonlinear_function_sg Class Reference
Detailed Description
A spherical_gaussian lobe is defined as \(k_s exp(n (v.p - 1))\). Where \(n\) is the roughness control and \(p\) is the lobe direction and \(v\) the evaluation direction.
Plugin parameters
#include <function.h>
The documentation for this class was generated from the following file:
