ALTA  alpha
nonlinear_function_ward Class Reference
Detailed Description
A ward lobe is defined as \({k_s \over 4 \pi \alpha_x \alpha_y \sqrt((i.n) (o.n))} exp(- ({(h.x) / \alpha_x)^2 + ((h.y) / \alpha_y)^2 \over (h.n)^2}\). Where \((\alpha_x, alpha_y)\) is the anisotropic roughness control.
Plugin parameters
#include <function.h>
The documentation for this class was generated from the following file:
