ALTA  alpha
Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
rational_fitter_eigen Class Reference
Detailed Description
Todo:
: WRITE MORE
#include <rational_fitter.h>
Collaboration diagram for rational_fitter_eigen:
Collaboration graph
[legend]
virtual bool fit_data (const ptr< data > &d, ptr< function > &fit, const arguments &args)
virtual void set_parameters (const arguments &args)
 parse the command line arguments to setup some general options before any fit. Those options should be resilient to multiple call to the fit_data procedure
- Public Member Functions inherited from alta::fitter
virtual bool fit_data (const ptr< data > &d, ptr< function > &f, const arguments &args)=0
 static function to fit a data set d with the underling function class. Return the best fit (along with fitting information ?)
virtual bool fit_data (const ptr< vertical_segment > &d, int np, int nq, const ptr< rational_function > &fit)
virtual bool fit_data (const ptr< vertical_segment > &dat, int np, int nq, int ny, rational_function_1d *fit)
int _np
int _nq
The documentation for this class was generated from the following files:
