ALTA  alpha
rational_fitter_leastsquare Member List
This is the complete list of members for rational_fitter_leastsquare, including all inherited members.
_max_iter (defined in rational_fitter_leastsquare)rational_fitter_leastsquareprotected
_np (defined in rational_fitter_leastsquare)rational_fitter_leastsquareprotected
_nq (defined in rational_fitter_leastsquare)rational_fitter_leastsquareprotected
fit_data(const ptr< data > &d, ptr< function > &fit, const arguments &args) (defined in rational_fitter_leastsquare)rational_fitter_leastsquarevirtual
fit_data(const ptr< vertical_segment > &d, int np, int nq, const ptr< rational_function > &fit) (defined in rational_fitter_leastsquare)rational_fitter_leastsquareprotectedvirtual
fit_data(const ptr< vertical_segment > &dat, int np, int nq, int ny, rational_function_1d *fit) (defined in rational_fitter_leastsquare)rational_fitter_leastsquareprotectedvirtual
alta::fitter::fit_data(const ptr< data > &d, ptr< function > &f, const arguments &args)=0alta::fitterpure virtual
rational_fitter_leastsquare() (defined in rational_fitter_leastsquare)rational_fitter_leastsquare
set_parameters(const arguments &args)rational_fitter_leastsquarevirtual
~fitter() (defined in alta::fitter)alta::fitterinlinevirtual
~rational_fitter_leastsquare() (defined in rational_fitter_leastsquare)rational_fitter_leastsquarevirtual
