ALTA  alpha
rational_fitter_matlab Member List
This is the complete list of members for rational_fitter_matlab, including all inherited members.
_max_np (defined in rational_fitter_matlab)rational_fitter_matlabprotected
_max_nq (defined in rational_fitter_matlab)rational_fitter_matlabprotected
_min_np (defined in rational_fitter_matlab)rational_fitter_matlabprotected
_min_nq (defined in rational_fitter_matlab)rational_fitter_matlabprotected
_use_matlab (defined in rational_fitter_matlab)rational_fitter_matlabprotected
ep (defined in rational_fitter_matlab)rational_fitter_matlabprotected
fit_data(const ptr< data > &d, ptr< function > &fit, const arguments &args) (defined in rational_fitter_matlab)rational_fitter_matlabvirtual
fit_data(const ptr< vertical_segment > &d, int np, int nq, const ptr< rational_function > &fit) (defined in rational_fitter_matlab)rational_fitter_matlabprotectedvirtual
fit_data(const ptr< vertical_segment > &dat, int np, int nq, int ny, rational_function_1d *fit) (defined in rational_fitter_matlab)rational_fitter_matlabprotectedvirtual
alta::fitter::fit_data(const ptr< data > &d, ptr< function > &f, const arguments &args)=0alta::fitterpure virtual
rational_fitter_matlab() (defined in rational_fitter_matlab)rational_fitter_matlab
set_parameters(const arguments &args)rational_fitter_matlabvirtual
~fitter() (defined in alta::fitter)alta::fitterinlinevirtual
~rational_fitter_matlab() (defined in rational_fitter_matlab)rational_fitter_matlabvirtual
