ALTA  alpha
Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
rational_fitter_parallel Class Reference
Detailed Description
You can find QuadProg++ here.
Plugin parameters
We provide the following command line arguments to manipulate this plugin:
#include <rational_fitter.h>
Collaboration diagram for rational_fitter_parallel:
Collaboration graph
[legend]
virtual bool fit_data (const ptr< data > &d, ptr< function > &fit, const arguments &args)
virtual void set_parameters (const arguments &args)
 parse the command line arguments to setup some general options before any fit. Those options should be resilient to multiple call to the fit_data procedure
- Public Member Functions inherited from alta::fitter
virtual bool fit_data (const ptr< data > &d, ptr< function > &f, const arguments &args)=0
 static function to fit a data set d with the underling function class. Return the best fit (along with fitting information ?)
virtual bool fit_data (const ptr< vertical_segment > &d, int np, int nq, const ptr< rational_function > &fit, const arguments &args, double &delta, double &linf_dist, double &l2_dist)
virtual bool fit_data (const ptr< vertical_segment > &dat, int np, int nq, int ny, rational_function_1d *fit, const arguments &args, vec &p, vec &q, double &delta)
virtual void get_constraint (int i, int np, int nq, int ny, const ptr< vertical_segment > &data, const rational_function_1d *func, vec &cu, vec &cl)
 Create a constraint vector given its index i in the data object and the rational function object to fit. This function returns two rows of the constraints matrix A, cu and cl, corresponding to the lower constraint and the upper constraint of the vertical segment.
int nb_starting_points
Member Data Documentation
int rational_fitter_parallel::nb_starting_points
protected
Number of points used when starting the adaptive interpolation procedure. By default, this value is 100.
The documentation for this class was generated from the following files:
