ALTA  alpha
Public Member Functions | List of all members
rational_function_chebychev Class Reference
Detailed Description
This rational function uses Chebychev polynomials as the basis function for the numerator and the denominator of the rational function:
\( f(x) = \sum a_i p_i(x) / b_i q_{i}(x) \), with \( p_i = q_i\).
Chebychev polynomials can be defined using trigonometric functions: \( p_i(x) = \cos\left( i \; \mbox{acos}(x) \right)\). We use this formulation.
For more details see the addendum on Rational BRDF available at
Laurent Belcour <>
#include <rational_function.h>
Collaboration diagram for rational_function_chebychev:
Collaboration graph
 rational_function_chebychev (const alta::parameters &params, int np=0, int nq=0)
virtual rational_function_1d * get (int i)
Update the y-1D function for the ith dimension.
It will test if the 1D function provided is of the dynamic type
virtual void update (int i, rational_function_1d *r)
Member Function Documentation
rational_function_1d * rational_function_chebychev::get ( int  i)
Get the 1D function associated with color channel i. If no one exist, this function allocates a new element. If i > nY, it returns NULL.
The documentation for this class was generated from the following files:
