ALTA  alpha
Public Member Functions | Protected Member Functions | List of all members
schlick_fresnel Class Reference
#include <function.h>
Collaboration diagram for schlick_fresnel:
Collaboration graph
[legend]
 schlick_fresnel (const alta::parameters &params)
virtual bool load (std::istream &in)
 Load function specific files.
virtual void save_call (std::ostream &out, const arguments &args) const
 default non_linear export. It will dump the parameters in order but won't assign names for the function nor parameters.
virtual void save_body (std::ostream &out, const arguments &args) const
 save function specific data. This has no use for ALTA exportbut allows to factorize the code in the C++ or matlab export by defining function calls that are common to all the plugins. More...
- Public Member Functions inherited from alta::nonlinear_function
 nonlinear_function (const parameters &params)
virtual void bootstrap (const ptr< data >, const arguments &args)
 Provide a first rough fit of the function. More...
- Public Member Functions inherited from alta::function
virtual ~function ()
 Destructor function needed when using shared_ptr.
virtual void save (const std::string &filename, const arguments &args) const
 Save the current function to a specific file type, args can be used to differenciate the type of export. More...
virtual void save_header (std::ostream &out, const arguments &args) const
 save the header of the output function file. The header should store general information about the fit such as the command line used the dimension of the fit. L2 and L_inf distance could be added here.
double L2_distance (const ptr< data > &d) const
 L2 norm to data. More...
double Linf_distance (const ptr< data > &d) const
 Linf norm to data. More...
virtual void setMin (const vec &min)
virtual void setMax (const vec &max)
virtual vec min () const
virtual vec max () const
const parametersparametrization () const
void setParametrization (const parameters &p)
virtual vec operator() (const vec &x) const
virtual vec value (const vec &x) const
virtual int nbParameters () const
 Number of parameters to this non-linear function.
virtual vec parameters () const
 Get the vector of parameters for the function.
virtual void setParameters (const vec &p)
 Update the vector of parameters for the function.
virtual vec getParametersMin () const
 Get the vector of min parameters for the function.
virtual vec getParametersMax () const
virtual vec parametersJacobian (const vec &x) const
 Obtain the derivatives of the function with respect to the parameters.
virtual void bootstrap (const ptr< data > d, const arguments &args)
 Boostrap the function by defining the diffuse term.
Additional Inherited Members
- Protected Attributes inherited from alta::function
parameters _parameters
vec _min
vec _max
Member Function Documentation
void schlick_fresnel::save_body ( std::ostream &  out,
const arguments args
) const
virtual
save function specific data. This has no use for ALTA export but allows to factorize the code in the C++ or matlab export by defining function calls that are common to all the plugins.
Reimplemented from alta::function.
The documentation for this class was generated from the following files:
