ALTA  alpha
Classes
Core
Collaboration diagram for Core:
Detailed Description
Classes
class  alta::arguments
 A useful class for storing the high-level arguments of a program or a function. More...
class  alta::data
 A data object. Allows to load data from files. More...
class  alta::data_params
 Change the parametrization of data to fit the parametrization of the function to be fitted. More...
class  alta::fitter
 Fitting interface for generic fitting algorithms. More...
class  alta::function
 A representation of an analytical function. More...
class  alta::nonlinear_function
 Non-linear function interface. More...
class  alta::compound_function
 A compound (sum) of multiple nonlinear functions. This allows to perform the fit of multiple lobes at once. More...
class  alta::product_function
 A product of nonlinear functions. This class aims to simplify the fitting and progressive fitting of Fresnel effects that can be separated from the main lobe. More...
class  alta::vertical_segment
 A vertical segment data class. More...
class  alta::params
 a static class allowing to change from one parametrization to another. More...
class  alta::plugins_manager
 This class permits to load plugin from shared library files. More...
