ALTA  alpha
Classes
Data plugins list
Collaboration diagram for Data plugins list:
Detailed Description
This page reference the different Data plugins available in ALTA. A data plugin enables to load/save and evaluate data measurements for a given position.
We list below all accessible data plugins in ALTA. To use one of those, please use the name referenced here. For example, to load and use a data plugin compatible with MERL data you will need to call for example:
From the command line:
--data data_merl
In the python interface:
alta.get_data('data_merl')
In a XML script:
<plugin type="data" name="data_merl" />
The plugin vertical_segment is ALTA internal format and can be used to store and load either ASCII gnuplot compatible or binary data. It is fully integrated into the core of ALTA library and is therefore not exposed as a shared library.
Classes
class  alta::vertical_segment
 A vertical segment data class. More...
class  data_grid
 Data object storing BRDF values on a grid. Can perform linear interpolation between grid cells. More...
class  data_interpolant_matlab
 This plugin provide an interpolation of vertical_segment data using Matlab griddata functions. More...
class  data_interpolant_rbf
 This plugin provide an interpolation of vertical_segment data using Radial Basis Function interpolation. More...
class  data_astm
 Data interface for the ASTM file format from Cornell University. More...
class  data_merl
 Data interface for the MERL file format. More...
class  data_brdf_slice
 Data interface for the BRDF slice file format. More...
class  data_utia
 Data interface for the UTIA file format. More...
