ALTA  alpha
Classes
Plugins
Collaboration diagram for Plugins:
Detailed Description
Classes
class  nonlinear_fitter_ceres
 A non-linear fitter using the CERES solver. More...
class  nonlinear_fitter_eigen
 A fitter for non-linear BRDF models that uses Eigen's Levenberg-Marquardt solver. More...
class  nonlinear_fitter_ipopt
 A non-linear fitter using the COIN-OR IpOpt solver. More...
class  nonlinear_fitter_nlopt
 A non-linear fitter using the NLOpt solver. More...
class  rational_fitter_eigen
 A least square fitter for rational function using the library Eigen. More...
class  rational_fitter_leastsquare
 A least square fitter for rational function. More...
class  rational_fitter_matlab
 A plugin to fit rational function using the Matlab Engine. More...
class  rational_fitter_parallel
 A vertical segment fitter for rational functions that search for a solution for a fixed number of coefficient. This plugin can run in parallel with OpenMP and is using QuadProg++ quadratic solver. More...
class  rational_fitter_quadprog
 A vertical segment fitter for rational function using the library QuadProg++ You can find the library here: http://quadprog.sourceforge.net/. More...
class  data_interpolant_matlab
 This plugin provide an interpolation of vertical_segment data using Matlab griddata functions. More...
class  data_interpolant_rbf
 This plugin provide an interpolation of vertical_segment data using Radial Basis Function interpolation. More...
class  data_astm
 Data interface for the ASTM file format from Cornell University. More...
class  nonlinear_function_abc
 The ABC distribution of Low et al. [2012]. More...
class  nonlinear_function_lafortune
 An isotropic Lafortune BRDF. More...
class  nonlinear_function_retrobeckmann
 An empirical retro-reflecting BRDF model based on a Beckmann distribution (see Belcour et al. [2014]). More...
class  nonlinear_function_sg
 A spherical Gaussian lobe class. More...
class  nonlinear_function_ward
 Ward's anisotropic BRDF model. More...
