ALTA  alpha
XML scripts
You can create XML formated files to run ALTA complex commands. A python script xml_cmd.py is available in the directory #/sources/scripts. You can use it with the following command: #/sources/scripts/xml_cmd.py file.xml
We provide an example XML file that is self describing:
1 <?xml version="1.0"?>
2 <alta>
3  <action name="data2brdf">
4
5  <input name="../data/3d/merl/blue-metallic-paint.binary" />
6  <output name="./results/3d/merl/blue-mettalic-paint.brdf" />
7
8
9  <function name="nonlinear_function_diffuse" />
10  <function name="nonlinear_function_beckmann" />
11
12
13  <plugin type="fitter" name="nonlinear_fitter_ceres" />
14
15
16  <plugin type="data" name="data_merl" />
17
18
19  <parameter name="export" value="explorer" />
20  </action>
21 </alta>
The <input> command can take two different kind of attributes:
